Pergo Flooring
I've recently installed original Pergo flooring. Everything has gone smoothly but I did end up with some small gaps in a couple places. What can be done to mask these? Does Pergo supply some filler or is there another method?
How could you end up with gaps. Purgo flooring is tongue & groove. If they are not tight together, your flooring is going to come up. No fillers needed.
Jack the Contractor
Jack the Contractor
