edging a laminated hardwood floor around an irregular fireplace
I put a hardwood floor in around an irregular stone fireplace 3 years ago for my son. Go buy yourself a contour gage at Lowes, Home Depot, etc. This will allow you to make a pattern you can transfer to the wood to cut out. Our end grain butted against the stone. Don't make the fit tight as the wood needs room to expand and the fireplace will also when a fire is in it.
Good luck!
Good luck!
