need help quickly
Installing prefinished engineered hardwood planks over wood subfloor (glue down) No obvious moisture problems. What type of barrier (if any) is best to use. Thanks
John, there are moisture barriers than are troweled on. Franklin made one that was like a foil that was glued down. If you're on a wood subfloor you can use felt paper under the particle board for a little protection or you can use visqueen in the crawl space. Just a few examples that are compatible with glued down installations.
Scott www.stephensfloor.com
