flooring over hot water radiant heat
Old 09-02-00, 02:56 PM
Guest
Post
Our home is heated with radiating hot water through the floors. Both levels are above ground, the lower is concrete, the upper is plywood. We'd like to install hardwood. Can we do this without damaging the hoses carrying the hot water underneath the concrete or plywood?
Old 09-03-00, 07:01 PM
Guest
Post
Yes. You can use sleepers or just install a floating floor.
Scott Stephens www.stephensfloor.com
