Fixing Small Gaps in Pergo Floor Near Doorfame
Old 09-13-00, 09:41 AM
Guest
Question
I just installed Pergo and the molding. However, near the door frame, the molding does not cover the "spacing gap" that we left around the door frame. Luckily the T-molding and the side molding covered most of it but, there are still quarter sized gaps near the door frame.
An installer told me we should have cut underneath the door frames when installing.
Any suggestions?
Old 09-13-00, 01:13 PM
Guest
Cool
Mike:
The installer is right and the only option left is to caulk the areas. Most installations instructions call for undercutting the door casings.
Old 09-14-00, 12:53 PM
Guest
Post
If you havn't missed by very much you might be able to shim the door casing out to cover the gap, not that Iv'e ever had to do it myself.
Scott Stephens www.stephensfloor.com
