Pergo Casual Living
Old 04-05-10, 04:22 PM
I
Pergo Casual Living
Hi
I am installing Pergo in a bedroom with a wood subfloor. This room is above a crawl space with a concrete floor. I have been told that I do not need to put plastic moisture barrier under the pergo. I was told to roll out tar paper and install the pergo over this. Any suggestions?
Old 04-08-10, 01:56 PM
T
My first suggestion would be to quit listening to whoever is giving you that advice. lol.
A plastic vapor barrier is not required on a plywood subfloor, but tar paper (asphalt saturated felt paper) is not for use under a floating floor. Tar paper would only be used when stapling/nailing hardwood floors. Under the pergo, you need to use an underlayment designed for floating floors (foam, rubber,cork, etc.). Many have vapor barriers attached, but one with a vapor barrier is not required. If you want to stay cheap, go to HD and pick up their 1/8" white foam underlay pad, will probably run you 25-30 cents a s/f.
