Old Hardwood floor...Need Planing?
Old 04-15-10, 04:35 PM
Hi, I have a hardwood floor that used to be a verandah...I was thinking about sanding and sealing it but my Dad reckons that for old boards like that you have to plane about 1/8 of an inch off the surface in order to get it back to a super-smooth finish.
I've looked at it in several places (just lifting up the carpet) and it seems fairly smooth already. I'd say 75% of the area you could rub your hand over it without worrying about splinters, the rest is a little rough around the seams and edges.
This is meant to be a quick DIY job, and it's not a feature room or anything, my parents were just using it as storage before I said I wanted to move in there. I was hoping I could sand it, vacuum it, use some filler to fill any remaining rough bits and then seal it. What do you think?
Cheers
Sam
Old 04-16-10, 03:39 AM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Planing is almost too drastic. I believe you can achieve satisfactory results using a belt type flooring sander, then applying a finish.
Old 04-16-10, 04:45 AM
Received 875 Upvotes on 766 Posts
I agree that a drum sander does the best job of sanding the floor down but they can be tricky for a diyer to use. A floor buffer [with sanding pad/screen] is a lot more forgiving although you won't be able to sand as deep as you can with a drum sander.
Old 04-16-10, 04:14 PM
mickblock's Avatar
Received 1 Upvote on 1 Post
If the floorboards aren't rippled, otherwise warped or discolored and only need sanding, you could even use a palm sander. Just do some research on finishing floors before you seal.
With the kind of grit that is available even with rental buffer type sanders, (gravel driveway on a plate) it wouldn't matter if a solid wood floor was warped. You could still fix it without taking it up. It would have to be pretty extreme to warrant planing.
Old 04-16-10, 09:16 PM
Great thanks guys...I might start with one of those little hand sanders and do a bit near one edge and see how it comes up. If it looks OK then I'll pad my knees and get to work on the rest of it.
Cheers
Sam
