help! need quick hw floor replacement advice.
Old 05-17-10, 10:18 PM
i have to replace some areas of moisture damaged hardwood flooring and subflooring in my house..the moisture problem has been corrected..the house was built by a tract developer and the wood floors are the pre-finished type that lowe's sells.
i do not want to pay for replacing all the wood flooring and intend to do my best to match new and old floor..am i an idiot trying to do the impossible?.any suggestions or helpful information would be appreciated.
Old 05-18-10, 03:06 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Replacing the hardwood alone is not a problem, and completely DIY-able. Replacing the subflooring as well may prove to be a big deal. In order to do the subflooring, you will need to remove enough hardwood to span at least across 3 joists. How much damage are you talking about?
