Harwood floor repair
Uploaded with ImageShack.us
I would appreciate some advice on how to repair the floor where part of a wall used to be, I do have some floor boards available that I removed from a closet.
Im planning on refinishing all the floors
Floor is about 70 yrs old .
Thank you
I'm no pro, but I wouldn't just try to throw in boards in the gaps. If you have enough, I would take out some boards on each side of the gap and completely replace them with boards that will go all the way across the gap. You could also reuse some of the other boards too. That way you don't have a weird looking section where all of the seams line up.
If you decide to take boards out and move them, play around with them until you get the look you want.
I don't think you will ever match end for end with newer boards. I would smooth up the ends as much as possible. Yours only shows one board to be too short, and I am amazed the remainder are squared off. It doesn't happen much in modern installations. Run your new boards perpendicular to the existing flooring, forming a threshold. You will need to remove the tongue from the last board and possibly split it to fit in the gap. Once installed, the shoe molding or base you will install should dress up the edges. Fill in any gaps with matching wood putty and finish the floors like you planned.
Thank you for replies
Im wondering now if some one can tell what kind of wood is it [ house build 1938]
Regards
Regards
If I were doing the patch, I'd cut on the gray lines on the bottom of the picture to create new butt ends. then remove the wood from inside the closet. If the tongues are facing to the left, start on the right side and work left. If tongues face to the right, work from left to right. Then, using a good adhesive (I'd use construction glue) glue the area of the board you slide in where you cant nail on the tongue of the board. Rubber headed mallets work good for sliding boards in. When you get your first board in, cut the piece to run up to the wall and nail it in, and work to your next row. Does this make sense? It sounds like a lot, but its easier than you think. Cutting the new butt ends in the "room" can be done with a hammer and a sharp chisel, or if you have one of those Fein or Rockwell vibrating saws (<- Fein saws are what we use at work but I've heard the rockwells will do the job too.)
Thanks for the guidance on the patching job,the explanation is very clear
I was traying to determine the kind of wood as Im planning on staining the floors darker than what they are and dont know if birch or maple will take a dark stain well
Regards
Regards
Neither specie will take stain very well by itself. You can get it to take color better if you "water pop" the grain but it will still end up blotchy. IMO, don't stain it. Old birch and maple looks so much better with a natural finish. Old growth wood shouldn't be stained (again, IMO).
Can you suggest a product for a natural finish?
Thank you
Thank you
If you are doing it yourself, I'd use an Oil based polyurethane for floors. Floor finish is a thicker more durable finish than any of the "fast drying" finishes on the shelf.
If you want to coat the floor the easy way, don't use a lambswool block like the directions say. Get a "T-bar". These have a swivel and make coating a breeze. T-bar applicators are tube shaped and use the same material as flat "paint pads" do. (foam/nylon bristles).
Thank you again, when sanding the floors what grits should I use considering there isn't any thing major to get rid of?
Regards
Regards
On that floor, you should be able to 36-50-80 that floor. However, old floors sometimes have shellac or wax on them and this finish will melt and stick to your paper. If this starts to happen with your 36 grit, I'd pull it off before it gets too clogged and put a 16 grit or 24 grit on to get the finish off, then go back to your 36 grit. After sanding, I'd buff the floor with a 100 grit sandscreen.
Thank you so much for all the help.
Regards
Regards
Previous Thread
Next Thread
