Framing around fireplace hearth
Old 12-08-00, 05:43 AM
Guest
Question
I am putting 3/4" unfinished oak strip flooring in my family room. The family room has a fireplace with a brick hearth. I would like to use 4" or 6" wide 3/4" oak to build a "frame" around the hearth on the floor and then butt the strip flooring into this frame (rather than running the strips right up to the hearth).
Here is an attempt at a ASCII drawing of what I have in mind:
| | | | Brick | || |
| | | | Hearth | || |
| | | |___________| || |
| | |________________ _|| |
The flooring directions is running with the end grain towards the fireplace. The room is about 14' X 20' with the fireplace on one of the 14' walls. The hearth sticks out into the room about 1.5', and is about 3.5' wide.
If I do this, will I have problems if I do not leave an expansion gap between the strip floor and the frame around the hearth? I am concerned because the part of the frame in front of the fireplace will have the grain at a 90 degree angle to the grain in the rest of the floor.
I want to leave a gap between the wood frame and the brick hearth. What (if anything) should I use to fill this gap so that debris doesn't fall into the crack but will still allow the wood to expand and shrink?
Thanks,
David
Old 12-08-00, 05:46 AM
Guest
Oops, I guess the ASCII drawing didn't work.
-David
Old 12-09-00, 07:30 AM
Elite Flooring/Ken Fisher
Lightbulb
David:
Your description is very clear to me, and thanks for the details. I've heard one suggestion on one message board(floorboards.com) that made alot of sense to me and I never considered it. Considering your flooring dimensions are not that great, I would leave 1/4" expansion around the hearth perimeter and 1/2"- 5/8" on the room perimeter.
The suggestion I heard was to fill the 1/4" area with silicone caulk then sprinkle some brick dust to match the color of your hearth before the caulk dries.
Old 12-11-00, 02:08 AM
Guest
David, to get the best look while maintaining an expansion gap, undercut the hearth using an undercut saw with a masonry blade, then chip it out with a cold chisel. It's a little more work but it will look professional.
Scott Stephens
http://www.stephensfloor.com
