floating 3" vs 5" uneven subfloor
Old 09-11-10, 01:22 PM
T
i plan to float an engineered clicklock floor and i'm wondering if plank width makes a difference as to minimizing problems from uneven spots in subfloor -- are wide planks better than narrow planks, vice versa, or no real difference? i will of course level subfloor best i can. It is particle board which i realize is a risk
thanks
Old 09-11-10, 06:28 PM
T
my thinking is that since floor made of narrower planks would have more joints, it would be somewhat more flexible and so would lay better over subfloor unevenness than a wide plank floor would. but i'm not sure this is right or that any difference either way would be significant
Old 09-12-10, 09:57 AM
C
do yourself a favor = flatten the floor !!!
Old 09-12-10, 12:12 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
The flooring may flex in one direction, but not in both, so leveling the floor would make much better sense. That way you can install whichever you "like", rather than making do with what will fit.
Old 09-13-10, 09:04 AM
Received 1,262 Upvotes on 1,203 Posts
One more vote for fixing the subfloor
