Narrow strip of laminate flooring
Old 09-28-10, 06:09 PM
G
I've installed two laminate floors before and will be doing another one shortly. On this floor, there is a narrow (6") wide strip of the floor that follows along the top of a staircase. Any suggestions on how to install such a narrow strip? What will keep it from moving?
Old 10-05-10, 06:01 AM
W
narrow strip
i have worked with hundreds of laminate flooring. do u have a picture of what your talking about? Im not sure what exactly your talking about. is it a on the stair?
Old 10-13-10, 05:57 PM
G
I'm not quite sure how to load a picture. Sorry, I do have one. Basically, it's about a 6 inch strip that lays between floor to ceiling windows (part of a sliding glass door onto a deck) and a stairwell on the other side. The strip doesn't go down the stairwell, it runs along the top of the stairwell.
Old 10-13-10, 06:00 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Old 10-14-10, 05:52 AM
G
Ok, I think I can put a photo in.
Thanks for the help with photos.
Old 10-14-10, 05:58 AM
G
Ok, maybe not. Here's a link that works. I have to replace the carpet here with laminate flooring. Because this is such a narrow strip, should I be securing it somehow like gluing it down etc. Nobody really walks on this part.
Ledge 3 | Flickr - Photo Sharing!
Old 10-14-10, 07:24 AM
kolias's Avatar
Received 9 Upvotes on 9 Posts
Assuming that there is a wooden subfloor why you don't use some panel nails or construction adhesive?
