Scratches on Parquet Flooring
Old 10-07-10, 05:11 AM
W
Received 66 Upvotes on 57 Posts
Will be trying to repair scratches on parquet wood flooring. The floor covering is several years old. I believe sanding and refinishing the scratched areas would not match the other flooring. The scratches were caused by furniture being scooted across the floor. The scratches are white in appearance. The wood colors range from Dark Walnut to Honey Oak. Is there a product which will remove the white discoloration?
Old 10-07-10, 11:21 AM
Received 875 Upvotes on 766 Posts
Have you tried using mineral spirits? It might remove the white.
Old 10-08-10, 04:50 AM
W
Scratches
Thank you, Marksr. Will begin work next week. Your idea of using mineral spirits is an excellent one which I had not thought about. Thanks! I will give it a try.
Old 10-23-10, 01:21 PM
W
Scratches
The mineral spirits worked. Thanks again.
