Adhesive residue on hardwood flooring
Old 01-27-11, 11:58 AM
I was having a mouse problem at my house. I found a mouse hole in the corner of 2 seperate closets. I bought the "Big Gap Sealer foam/insulator" to seal these holes, which it worked like a champ, no more mices!!. My entire house is White Oak Hardwood floors and I had them refinished about 2 years ago. My house is still under remodel so I have not put the trim on the baseboards in these closets. Well, when I filled the mouse holes with the big gap sealer, the foam expanded onto the hardwood flooring leaving a hard dried residue on the hardwood flooring. I tried to scrape it up with a plastic scraper but it is not working. Is there anything I can do to get this residue up without sanding and refinishing? I have heard natural peanut butter might work or lemon juice? not For sure and any help will be greatly appreciated!
Old 01-27-11, 12:40 PM
Gunguy45's Avatar
Super Moderator
Most likely the only thing that will take it off is acetone (nail polish remover) which will prob damage the finish. The non-acetone polish remover might work..but may affect the finish as well.
I'd probably spray some foam on cardboard and see what will dissolve it. Then maybe try a small out of the way area of flooring.
Pro's will be around....
Oh...did you check the manufacturers website for removal options?
Old 01-27-11, 01:08 PM
Go with the peanut butter, the peanut oil will disolve almost all adhesives with out harmful effects to the the surface. Works on clothes and material with no staining.
Old 01-27-11, 01:10 PM
I've heard acetone for this as well
Nasty stuff, probably have to refinish - not sure whether I'd bother for the corner of a closet, though
