how to cure this problem....
Old 02-14-11, 12:27 PM
We have pine floors. The sun has bleached a couple of areas over by the door/window areas (maybe a foot with 8' across). What is the best cure for this problem? I thought about putting new stain down, but it would only "sort of" match. Maybe that's about all I can do.....
Old 02-14-11, 01:17 PM
This is the way pine is, don't know that there's any long term solution for you
Old 02-14-11, 04:07 PM
chandler's Avatar
I'll let Marksr or others chime in on the "fix", but the "cure" would be 35% neutral gray 3M window tinting to help block the UV's. You may only need it on the west side of the house, check it out.
Old 02-14-11, 04:41 PM
I doubt you can touch up an area and get an acceptable job
The fix would be to sand down to raw wood and refinish
Old 02-20-11, 07:37 PM
Well thanks for all your words. Yes, I'll fumble around and try to do some kind of fix.
The thing about putting the window tinting on is a valuable tip to me. Only two doors would need that.
We'll press onward with the utmost of dispatch.......
