Flooring question.
Old 04-03-11, 07:00 PM
Flooring question.
Is there a laminate that looks like a 12 x 24 tile? Just curious because if there is I may go that route because I won't have to heat the floor. I can't stand cold tile and if I do the tile way then I will also need to spend to heat it.
Old 04-04-11, 03:20 AM
chandler's Avatar
Depends on where you will install it. Bathroom.....Kitchen......
You'd just have to shop around. I doubt anything will come in 12" widths. I laid a slate looking laminate once that was 8" wide with a varying rectangular pattern of up to 24".
Old 04-04-11, 03:32 AM
Any hard surface flooring will feel cold to the feet no mater what it is.
If this is going to be a kitchen or bathroom never use hard wood or laminite due to the chance of water damage.
Take a look at Allour flooring at Home Depot. Super simple to install with just a set of metal snips. They have it that looks like tile and real wood.
Old 04-04-11, 07:57 AM
There is vinyl that looks a lot like ceramic
Old 04-13-11, 11:21 AM
Definatley bad idea for laminate in a wet area.
IVC makes a wonderful looking fiberglass backed vinyl that looks really REALLY good. It is structurally stable: no curling or shrinking. and is cushioned which provides added R value and comfort.
As far as tiled laminate, if a dry area, Quickstep makes some nice tile looks, but probably not the 12x24" profile
Old 04-13-11, 03:31 PM
I have decided on tile. I am going to heat it and make it cozy. Going with a daltile - COLORBODY PORCELAIN - Vibe - Techno Brown. Polished. Looks cool and very modern.
Old 04-19-11, 03:43 PM
floor and decor has a laminate that looks like 12x18 tile. I agree with your choice of tile tho. We decided to go with 22x22 porcelain in our kitchen.
Tawny Laminate F&D Express - $2.27 | Floor & Decor Outlets
