Floor molding
Old 05-07-11, 07:13 PM
Floor molding
Does anyone know if there is a transition molding for laminate flooring that bends and blends with the wood?
Old 05-08-11, 03:57 AM
chandler's Avatar
Patty, welcome to the forums! Not sure what you mean by "bends". Can you give us a little more information as to what the project will entail? Maybe you could even post a couple of pictures (not close ups) of the affected area. It would help us to see what you are seeing. http://www.doityourself.com/forum/el...your-post.html
Old 05-08-11, 07:14 PM
jatco's Avatar
There are many co's out there that manufacture 'flexible' moldings/trim. Seen it used many times for radius corners etc. Many flooring co's have to use just what your talking about, to make transitions from 1 type of flooring to another with an arch/curve set-up.
Not uncommon...!
Just did a quick search and found this...
..:: Zago - FlexibleTrim.com ::.. Manufacture of Flexible Molding, Plastic Moldings, Crown molding, and Plastic casing.
Im sure there are others out there as well...
Who did your flooring? --yourselves.. or a contractor?
