Question on floating hardware floor
Old 06-03-11, 03:38 PM
A
can i install a floating hardwood floor over mexican tile
Old 06-03-11, 05:39 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Hardwood flooring does not float. It is nailed down. You have laminate (thin), and engineered hardwood flooring, which click locks together. You can install it over the tile, but you will have a giant transition from that room to the next, nearly 3/4" with proper padding. Let us know what problems you see with that.
