Quick Step Uni-Clik Glueless questions
Old 08-02-11, 11:04 AM
R
I am starting my first laminate job and have a question or two regarding transitioning.
Where do I stop the under cut going into a bedroom. Right before the door jamb or right past it?
I stopped the 3/8 plywood that I had put down on the subfloor right before the jamb.
Which transition piece should I use under the door?
thanks
Old 08-02-11, 03:54 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
If you close the door, your floor changes under the door. So your transition would sit directly under the closed door.
