Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Solid Hardwood, Engineered and Laminate Flooring
Reload this Page >
Dimple plastic as underlayment on concrete for basement laminate without osb
Old 11-01-11, 01:51 AM
W
Received 1 Upvote on 1 Post
deltaFL makes this product DELTAŽ-FL - Vapor Barrier for installation on concrete slabs, provides a warm and dry floor
I was wondering if anyone has use it on a basement floor with underpad and laminate ontop?
Does the plastic squeak when walking on it on does landscaping paper help the squeaking if its placed underneath the deltaFL plastic dimples?
Old 07-30-12, 05:36 PM
C
dimple under lam
I have worked with this product with per-go flooring, floor must be level and at least a sheet of luon under the lamination. you will have the same result as dri-cor with 1/4 the cost.
happy flooring (:
Old 07-30-12, 11:50 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
There's no way I would lay down luan on plain concrete in order to apply any flooring. You WON'T have the same results as DriCore, only a sloppy mess of a floor installation.
