Hardwood question - expansion space needed?
Old 11-16-11, 04:14 AM
Greetings,
Next week, I'll be installing 3/4" solid hardwood (nail down). The railing in the photo (see link) is where I'd like to start and my preference would be to put the boards right against the base of the railing. Will this pose problems? Should I keep a small space?
IMAG0351 | Flickr - Photo Sharing!
Old 11-16-11, 05:28 AM
sam floor's Avatar
Received 38 Upvotes on 32 Posts
It needs room for expansion and contraction.
Old 11-16-11, 05:42 AM
B
Received 47 Upvotes on 43 Posts
If you control your inside moisture level, humidify and dehumidify as needed you can minimize the expansion. If your house experiences a wide range of moisture levels, I've seem floors open up all over the place. Conversely, they will expand when the moisture returns.
Can you add a quarter round shoe to cover the required gap?
Be sure to acclimate your wood before you start.
Bud
Old 11-16-11, 08:25 AM
W
Received 33 Upvotes on 27 Posts
I guess it's once again time to ask my so far unanswered question about expansion.
Given normal temperature and humidity variations in a home, how much can a 2 1/2" strip floor expand when each individual plank is nailed down?
