Do I need a transition here or not? Laminate Question :)
Old 03-10-12, 05:00 PM
B
Working on my laminate install and am in a hall way that has a 1/2 bath attached.
I plan on going the SAME direction with the boards, so I am wondering if I need to put a T-Mold between hall and door, or just continue to click and go?
Thoughts???
Old 03-10-12, 05:48 PM
Doesn't look like a T-mold is necessary to me.
Old 03-11-12, 06:09 AM
chandler's Avatar
Received 4 Votes on 4 Posts
Once you enter the adjoining room, it may not be "square" to the room you left, leaving you vulnerable to gaps on the edges. If that room is a bathroom it would be ill advised to install laminate in there, anyway. If it is another room, then start on an opposite wall and work back to this doorway, installing a t molding in the opening, across where the stop molding is located.
