Laminate flooring - cutting to fit in odd-angled areas
Old 07-05-12, 10:03 AM
H
Hello, first time poster here. I am installing the cheap Ikea flooring into my entry way this weekend. I did the same for my kitchen last weekend. It was fairly easy once I got the hang of it, but I quickly discovered that most corners are not exactly ninety degrees!
So often times when I expected the board to just line up neatly against a wall, there would be a snug fit on one end of the board, and about a half inch space on the other.
Is there a trick to mark off the exact line to cut to fit into those spaces? I'm hoping there's a method that would solve this problem as well as other odd (non-90 degree) angles.
When I worked on the kitchen, I kind of did a trial and error method with the circular saw. Lots of errors and waste unfortunately.
I think I saw on TV once where the guy flipped over a board, moved it along the wall and the space he needed to fill, marked it off and made a perfect cut. I'd love it if there was something like this that I could do.
Or do I just need to measure the angle and mark it off like that?
Old 07-05-12, 10:10 AM
Received 94 Votes on 83 Posts
Welcome to the forums.
Lay the board you're going to cut exactly on top of the installed one it will be next to and then slide another one on top of that up against the wall. Draw a line on the middle board where the edge of the top one is and cut there.
Old 07-05-12, 01:00 PM
chandler's Avatar
Received 5 Votes on 5 Posts
You are leaving expansion space between the wall and the laminate, right? Uh-oh. If not it will buckle up in the change of seasons, humidity, etc. You leave at least 1/4" and install shoe molding around the existing wall/molding.
Old 07-05-12, 01:06 PM
Thanks, Chandler - I totally spaced on the expansion gap.
Old 07-05-12, 01:10 PM
chandler's Avatar
Got your back, Pilgrim!!....
