hardwood butting up to carpet and door jambs
Old 07-24-12, 02:56 PM
W
So i got the assumed answer to the hardwood or carpet question but my next one is:
do i install the door jambs (frames) before the flooring or vica-versa? also, i know the jamb needs to be under-cut for the hardwood to slide under but what about the carpet? do i just undercut the entire jamb the same height off the slab and have the carpet guy slide the carpet under?
any help would be great.
thanks,
justin
Old 07-24-12, 02:59 PM
Received 301 Votes on 267 Posts
Casing and baseboard is usually left about 1/2" off of the floor for the carpet to be tucked under.
Old 07-25-12, 07:22 AM
Received 94 Votes on 83 Posts
Yep, the door casing goes in first but doesn't go all the way to the ground. Regardless of the floor covering, you don't put wood or drywall all the way to the floor level to keep it from sitting in any moisture which might end up there.
Old 07-25-12, 12:35 PM
W
i was planning on doing door frames first but didn't know how high they typically sit for carpet- meaning if the carpet goes under them or not. i know to under cut for the wood floor, we have 5/8" but i wasn't sure if the entire frame would be 5/8" off the floor for the carpet too or it i install the frame and then just notice out the side for the hardwood.
Old 07-26-12, 08:19 AM
sam floor's Avatar
Received 15 Votes on 11 Posts
Carpet does NOT usually go under door frames. I have installed for 40 years and it's rare to see a door frame raised for carpet.
Old 07-26-12, 09:22 AM
I think we got mixed up on terminology
The jamb usually sets flat on the floor with allowances for uneven floor if needed.
The casing and base normally get raised for the carpet to be tucked under.
Old 07-27-12, 02:54 PM
W
ok, so you are saying that i will butting the hardwood and carpet up to the jamb. then ONLY the the base board and casing are raised on top of the hardwood and carpet....i thought i had read that people where undercutting the jamb to sit on top of the hardwood too....that is where i was/am confused.
