removing poly finish from laminate
Old 09-25-12, 03:03 PM
Unhappy removing poly finish from laminate
I want to remove the poly finish on my laminate floor that was put on by mistake. What steps to take?
Old 09-25-12, 03:11 PM
Received 120 Votes on 107 Posts
Welcome to the forums Kitty!
What type of poly was applied to the laminate, oil or waterbased? How long has it been on there?
I don't know that there is going to be any easy or quick method
Old 09-25-12, 07:53 PM
the poly used is waterbased and has been on the laminate floor about 3 years.
Old 09-26-12, 04:23 AM
The good news is the water based should be easier to remove than oil base poly. It's still not going to be easy. A couple of things to try would be scrubbing with a hot thinner like MEK or lacquer thinner and then scraping with a plastic "drywall" knife. Do a test area first!! There is going to be a fine line between removing the poly and harming the factory finish underneath. A citrus based paint remover might also be an option.
For the most part it's going to be trial and error as I doubt anyone has attempted a job like this
Old 09-26-12, 07:05 AM
Received 47 Votes on 44 Posts
Ugh. I think I might leave this alone - laminate is not wood but rather a picture of wood on a cardboard-like substrate; I would be concerned the process of removing the poly would damage the laminate.
Old 09-30-12, 06:48 PM
You are better off, buying new laminate.
The dull look you will certainly be left with, will bug you.
Old 10-01-12, 03:40 AM
chandler's Avatar
Received 2 Votes on 2 Posts
I agree with Perry, if the finish has been on for 3 years, that means the floor has been down for quite a longer time. I would, however, recommend an engineered floor rather than a clacky laminate. Just my preference, that's all.
