Do I have to stain?
Old 10-22-12, 07:21 AM
Received 2 Upvotes on 2 Posts
Do I have to stain?
Hello,
I am laying white oak hardwood in my entire house. (Except bath of course)
People keep telling me I have to stain the wood before coating with polyurethane.
But they were not able to give me a good explanation why.
Can you ?
Thank you
Old 10-22-12, 07:39 AM
Received 1,279 Upvotes on 1,217 Posts
Nope. Stain is coloring, you only need to stain if you want a different color to the wood.
Old 10-22-12, 07:44 AM
No, I do not want a different color. I like the look of the white oak.
It is friendly and light.
Old 10-22-12, 07:58 AM
How are you planning to finish it? Water based poly is clear, oil based poly adds a little bit of amber tint. Personally, I like the look of the oil based.
Old 10-22-12, 08:05 AM
I am using SW Wood Classics® Waterborne Polyurethane Varnish because of the non-yellowing.
Old 10-22-12, 08:45 AM
Yep, your final color is going to be close to your raw wood and it sounds like that's what you want. I think you're all set.
Old 10-22-12, 08:51 AM
yes, thank you for helping.
Old 10-22-12, 09:41 AM
Received 869 Upvotes on 760 Posts
Don't forget to remove ALL the sanding dust prior to applying the first coat. A light sanding will be required between coats and again, remove the sanding dust.
Old 10-22-12, 10:42 AM
Yes I will. Thank you very much
