Laminate floor with island- over or under?
Old 11-29-12, 06:33 AM
I'm scoping out buying an Armstrong Laminate floor for kitchen- Base cabinets are in already- We are installing a kitchen island with a 60" x 39" granite counter on the island. In reading the specs for the Laminate floor- it suggests if your island is over 250lbs- not to install the island directly on the floor- So I'm guessing my only option is to install the island now onto the subfloor and tile around it- Anyone else have any thoughts? My guess is the weight of the granite would crack the floor?
Old 11-29-12, 06:51 AM
Received 1,268 Upvotes on 1,208 Posts
Don't put the laminate under the island, it needs to move and and the island will prevent that.
Old 11-29-12, 12:51 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Laminate is the last thing I would put in a kitchen. You mentioned "tile" as an option. Now that's good.
Old 11-29-12, 01:12 PM
Just re-reading now and you're talking about granite countertops; laminate doesn't sound upscale enough for your kitchen.
