Water Damage To Hardwood Floor
Old 12-18-12, 02:02 PM
B
My house was built in 1951 with real hardwood all throughout. The wood is 3/4 thick, 1.5" oak planks running parallel to the floor joists. Subfloor is ?x6 planks running perpendicular to the joists/hardwood. I do not know the thickness of the subfloor.
I bought the house with some very worn down carpet, and a couple of years later I have decided to rip up the carpet and keep the wood floors throughout. However, I have one spot with what appears to me severe water damage. Link to the pics are below. I have a very strong desire to refinish these floors, but this damage is the kicker. Do you believe this can be sanded out, or are these boards junk? I do notice a slight buckling of the boards by feel of the hand. Definitely less than 1/16. Damaged circle is approx 4' across.
I have also attached a pic from another room as reference. A light sanding and poly would fix the rest of it right up.
thanks for the advice.
Old 12-18-12, 04:40 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Looking along the grain, it doesn't appear to have suffered irreparable damage. It may take more sanding than the other rooms, but I believe the original wood will eventually show through with only a couple of sanding sequences. As you know it will be a trial and error. You have very little to lose in trying to bring them back to life. Let us know how it turns out.
Old 12-19-12, 08:14 AM
Received 1,273 Upvotes on 1,213 Posts
Yep, start sanding and see what happens.
