Cracked stair tread
Old 01-18-13, 04:40 AM
Cracked stair tread
We live in a tri-level that was built in the late 70's and recently discovered that we have oak stair treads under the carpet. However, one of the treads in split lengthwise on the tread. The tread is encased in the stair frame. Is there some kind of way to fix this without resorting back to carpeting? I have a photo if I can figure out how to upload from my phone
Old 01-18-13, 05:24 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! In some instances it can be repaired. I'd wait on the pix to determine that. I don't post pix from my phone, but I do email them to my big boy computer, save them in a pix file then post them from there. http://www.doityourself.com/forum/el...your-post.html
Old 01-19-13, 12:49 PM
Pic
Here is a picture of the tread...you can see the crack that runs the full length of the step. I know it is fully split in two as the front section gives and squeaks when walking on it.
Old 01-19-13, 01:48 PM
chandler's Avatar
If you have finish nails (#8 x 2") drive them on either side and wherever you detect a stringer (probably 2 equidistant from edges) on either side of the crack and countersink them, puttying over the heads and polyurethane. They won't disappear, but they wont stand out and your tread should stabilize. You won't have a happy day removing and replacing the tread as it appears to be countersunk into the skirt board.
Old 01-19-13, 02:11 PM
Received 840 Upvotes on 737 Posts
Unless you have a nail gun, you'll want to predrill the nail holes. You can use colored putty on both the crack and the nail holes to make them disappear after you've snugged the tread up.
Old 01-19-13, 05:09 PM
chandler's Avatar
Good point, Mark. I don't use a hammer except to put wood in it's place before I use a nail gun, so I am spoiled. Point of interest, I would only drill through the tread, as you will want your nail to do super holding in the underlayer.
