My house is 123 years old. I have removed the carpet from one of the living
Old 01-31-13, 12:21 PM
E
areas and the wood underneath is really worn looking everywhere but a couple feet from the walls. The center looks like it would if someone ran a sander over it, but when I clean the floor and it is damp, the entire floor looks the same. Can I just seal the floor with something, making it all look uniform like it does when it is damp?
Old 01-31-13, 12:38 PM
Received 1,267 Upvotes on 1,207 Posts
Welcome to the forums.
Short answer is maybe, wiping some mineral spirits on there typically shows what a coat of polyurethane would look like on there (until the mineral spirits dry, of course) and I would imagine that wouldn't be much different than what you see when it's wet.
Old 01-31-13, 01:36 PM
Received 840 Upvotes on 737 Posts
I'd at least give it a light sanding, it won't hurt and may promote better adhesion. Normally it takes 3 coats of poly [sanding lightly between coats] to get a decent looking job.
