ME
02-04-13, 06:18 PM
underlayment for cork flooring?
I'm going to be putting down the click and lock cork flooring in a finished basement and I'm unsure whether I need some type of underlayment. It's my understanding the underlayment acts as a moisture barrier. However, the concrete floor has radiant heating in it, with 2" of foam board beneath the concrete. I would think an underlayment for the cork flooring would not be necessary. Thoughts?
WI
WI
02-05-13, 01:02 PM
It might be a simple answer but I tend to defer to whatever the manufacturer suggests and that can vary.
Someone like Chandler might be along in a few minutes with a good answer off the top of their head.
GA
02-05-13, 01:40 PM
I'll just have repeat what Mitch said. Not because the answer is simple, but because you have a warranty to worry about, not only for the flooring, but the heat as well. Wrong underlayment, no warranty. The manufacturer will be the best source of information on that subject.
But let us know what they say, as it can help us understand their criteria as well as help others on the forum.
ME
02-08-13, 10:20 AM
I found my answer from the manufacturer. You guys asked for an update if I was to hear back from them, so here is what they said:
"Underlayment is not necessary with our cork floors, but you will need to install 6mil polyethylene sheeting over the slab as a vapor barrier. The integrated cork backing will perform as the underlay."
Note, that refers to the Millstead plank cork flooring carried at Home Depot.
hope that helps someone
WI
