Flooring Transition Question???
Old 02-14-13, 12:28 PM
F
Putting down solid oak flooring in the kitchen and family room. This is 3/4" stock.
I have a laminate in an adjoining room with about a 6' archway where the two flooring materials will meet. The laminate is less than 3/8" thick.
My Oak flooring supplier (not a big box, a pure flooring manufacturer) says he does not know of any pre-made transition strips available.
Do I then need to make one somehow?
One would think that others have had this same issue and that a pre-made transition piece would be available.
Thanks for any tips.....
Old 02-14-13, 12:40 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I never buy store transitions. BUT I have the luxury of being able to make mine in my shop. If you have a table saw and good eye hand coordination, you can do the same. Just draw the profile on the end of a piece of oak stock and set the blade to make each cut.
