Painting chipboard flooring!!!
Old 02-14-13, 12:49 PM
Ive just ripped up the carpet and have the chipboard floor exposed. I would like to paint it White. Can anyone help me with advice as to what sort of prep and paint that I have to use for this. Its a living room and so it has to be hardwearing.
Old 02-14-13, 12:53 PM
Received 1,267 Upvotes on 1,207 Posts
Welcome to the forums.
I think of chipboard (OSB here) and floor paint both as not hardwearing. What are your actual expectations?
Personally, I also do not think this would look good and white will not likely stay white so I would not do this.
Old 02-14-13, 01:09 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Put a capital "U" on ugly and it says it all. OSB of itself is not a finished product, meant only for underlayment. Paint won't help. Someone mentioned in another thread, like putting perfume on a pig.
Old 02-14-13, 03:04 PM
Received 840 Upvotes on 737 Posts
If I had to paint an OSB floor and call it finished - it sure wouldn't be white! Several coats of a med/dark color would look best. Traffic and moving furniture around can cause some of the chips to come loose so plan on touch up and frequent repaints
Old 02-14-13, 03:20 PM
sam floor's Avatar
Received 37 Upvotes on 31 Posts
The moisture from the paint will most likely cause some swelling of the chips and will be rough on the feet.
Old 02-14-13, 08:07 PM
XSleeper's Avatar
Received 1,921 Upvotes on 1,725 Posts
I totally agree with the others that this is a very bad idea.
Having said that, the best paint to use would be a porch floor enamel, preferably oil based. Even if you use it you will still have the problems the others have warned you about.
Old 02-15-13, 04:51 AM
I thought I had mentioned that but re reading my post I guess I didn't
Oil base floor enamel will wear better than it's latex counterpart although other than some of the chips bleeding [tannins] thru a light colored latex, I doubt it will make much difference on an OSB floor. Did someone say something about a pig with lipstick?
Old 02-15-13, 05:51 AM
XSleeper's Avatar
pig with lipstick / like painting a corn cob. Oil primer first... then the oil porch floor enamel. I forgot to mention that too, although it should be a given.
