FLooring question
Old 02-21-13, 09:57 AM
FLooring question
I'm planning on tiling my bathroom, unfortunately i have particle subflooring. this brings me to a couple of questions. how thick would the plywood i lay down need to be if i am going to use cement backer board? and what would the best type of plywood and backerboard to use?
Old 02-21-13, 10:06 AM
Received 1,273 Upvotes on 1,213 Posts
Welcome to the forums.
Let's start with the basics - what's under the floor; what is the size, spacing and unsupported span of the floor joists?
Old 02-21-13, 12:56 PM
How can I get these measurements ? Looks like plywood underneath the particleboard.
Old 02-21-13, 03:18 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Is it particle board or OSB? What mitch is asking is what is your joist size (2x8, 2x10, etc. ) and what is the distance between any supporting member (wall, column, etc.). You'll probably have to go under the house or in the basement to view this.
Old 03-05-13, 05:47 PM
Excuse my absence. my brother went ahead and removed the sub flooring but now on the main floor which is plywood, has water damage where the toilet would stand. I am interested to know if you replace the areas where there is water damage or if you replace the entire floor? I do not believe the joists sustained any water damage. Underneath the floor (basement) the bathroom stands above the water heater. The joists are spaced 12''/ 1 foot apart. I'm unsure of joist size but they run from the main beam to the end which is AROUND 13'2" in length. side note: we moved into the house 2 years ago, and are unsure of other problems such as this water damage.
Old 03-06-13, 04:13 AM
Received 851 Upvotes on 747 Posts
How much of the sub floor is damaged? A pic or two might help - http://www.doityourself.com/forum/el...-pictures.html
Old 03-06-13, 07:04 AM
What was the reason for the water damage and has it been resolved?
Old 03-06-13, 02:05 PM
i am unsure of the water damage. i will post a couple of pictures of the floor. the water damage is heaviest where the toilet was.
Old 03-06-13, 02:36 PM
Leaking stools are common, you definitely want to fix a leak before putting down the new floor.
Old 03-06-13, 06:21 PM
there is no leakage that i have noticed for the past month from the time that removed the previous linoleum. I am assuming it was leaking because the wax seal was composed of wax only so the water could have been slowly seeping through.
Old 03-06-13, 06:41 PM
Floor
Size:  35.1 KBName:  photo-6.jpg
Size:  32.7 KBName:  photo-7.jpg
Sorry about the sideways. I could not figure out why they were being turned.
Can anyone answer why all those holes are there? hmmm.
Old 03-07-13, 03:15 AM
chandler's Avatar
They look like extrusion holes....you know to make it lighter in weight? No, that's not right. The elongated one may have been to countersink a toilet? Nooo! Aha! There was a woman involved with the design and she couldn't make up her mind where to put the toilet. That's it!!! Oooh, I'll catch it from Becky, now!
Old 03-07-13, 06:42 AM
I think i am just going to get me my plywood and replace the entire area. lol
Old 03-07-13, 07:14 AM
I think that might be the easiest way to proceed at this point.
