laminate and tile in the same room, just some hints
Old 02-27-13, 12:29 PM
A
Going for my first flooring project. Most of the kitchen will be a laminate floor with the backing already attached to the board. Think this will go pretty easy. However, around the door I want to install tile to provide a mud room area when you walk in. So do I just put cement board down where the tile is going? Do I need to use caulk under around the tile area (under the transition) or just add the transition. Any other hints or tips appreciated
Thanks
T
Old 02-27-13, 01:34 PM
Received 1,273 Upvotes on 1,213 Posts
What is your subfloor and what is the size, spacing and unsupported span of the floor joists?
