laying laminate under door jambs
Old 03-12-13, 12:58 PM
can any one advise me on how to lay the laminate under door jambs, I know how to cut away under the door jamb but the problem I have is that there is not enough room to tilt the laminate and click it into place and slide it under the door jamb as well ?
Old 03-12-13, 02:53 PM
czizzi's Avatar
Remove baseboard molding and door casing leaving just the door jamb. Make your cut such that it is in an "L" shape with the leg of the "L" in the doorway area. Install as normal and slide it under the door jamb as far as you can get it. Cut the corresponding piece as close a fit as possible with the cut just barely clearing the jamb. Connect the pieces and slide both pieces over to center on the jambs yet still tucked under. If I am installing shoe molding, I leave up the baseboard, undercut the baseboard about 2" and make an "S" shaped cut in addition to the "L" cut above and when you slide everything back to center, the laminate is partially tucked under the base molding as well.
