Non-US
03-29-13, 12:05 PM
What do I do if the floor dips over an inch towards a doorway?
I've attached a picture of my problem. It's a small bedroom that I was hoping to laminate until I removed all the old carpeting and saw how badly the floor dipped in one entire section towards a hallway. I'm really not sure what I would do to fix it as adding door skins or shingles would mean a ledge at the entrance to the hallway. Is re-carpeting the only solution?
WI
03-29-13, 12:23 PM
Welcome to the forums. Looks like a high spot in the middle as opposed to a low spot by the door, any idea what's causing that rise?
TX
03-29-13, 12:26 PM
You could probably float it out. First though I would want to check the joists out to see why there is a dip. If it wasn't fixable I'd sister new joists on to the existing joists so they were level. Assuming the dip runs the direction of the joists flush with the original joists at the beginning of the dip and above the original joist at the other end. If the joists run perpendicular to the dip you could just shim up the top of each joist but just sistering joists at the exact height needed might be easier the ripping shims the correct thickness.
Edit: If Mitch is correct my ideas may not work. I would still want to pull up some of the floor to see what as going on.
I can explain it to you, but I can't understand it for you.
Non-US
Non-US
04-03-13, 12:10 PM
Sorry to trouble you, but I've had two contractors take a look at the pictures and they both suggested:
".. remove the plywood at the highest point and sand down the Joists to bring the floor as level as possible before laminating."
Since the joists would only support the floor and not the walls, does this sound feasible?
WI
04-03-13, 12:34 PM
Removing the plywood to inspect the joists would be in order, not sure about sanding them.
GA
04-03-13, 01:30 PM
Assuming the floor was level when the construction of the house took place, something has happened. All the sanding in the world won't correct what has happened. You need to address why the floor rose, or the walls fell. You have a high spot, and it has probably affected door closings along this area as well. Do you have any access to the area below this room?
WI
