Transition help. laminate to tile.
Old 04-20-13, 09:48 AM
B
I am wondering what sort of transition would be recommended for the pictured install.
I will be removing the carpet and putting 12mm laminate down up to the tile. there is already a tile transitionstrip there, not sure if i need to remove it?
i am keeping the tile.
any advise/pictures?
thank you!
Old 04-20-13, 10:28 AM
czizzi's Avatar
Get a reducer that matches your laminate, and butt it up to the marble. The reducer will overlap the laminate and allow it to expand and contract while maintaining a finished look. Here is an example.
Home Legend Oak Verona 5/8 in. Thick x 2-1/8 in. Wide x 78 in. Length Hardwood Carpet Reducer Moulding-HL62CRS at The Home Depot
