removing carpet adhesive and old varnish from strip floor
Old 04-22-13, 02:59 PM
Received 1 Upvote on 1 Post
is there a chemical stripper anyone reccomend to strip off old carpet adhesive and old varnish from a douglas fir strip floor?
I tried hand scraping the glue off, but the varnish immediately gums up my sanding pad from the floor sander, belt sander. it doesnt matter. I've been using #36 and even tried #20. same result...paper gums up within seconds.
thanks!
Old 04-23-13, 03:40 AM
Received 821 Upvotes on 720 Posts
Scraping is likely your best bet. Sometimes paint thinner will dissolve and remove adhesive but I'm not sure you would want to use that much thinner indoors.
Old 04-23-13, 08:56 AM
I had read on another thread that Founders resortation system works well. If not for the floor, I have a set of stairs to do, that will be difficult to sand and/or scrape.
Old 04-23-13, 03:24 PM
I'm not familiar with founders restoration system, a quick search didn't turn up anything
Old 04-24-13, 08:40 AM
I'm sorry, its not Founders, its Formby's Furniture Refinisher.
From reading the directions, it seems like a long process to get through the whole flight of stairs.
Old 04-24-13, 10:38 AM
While I've used Formby's paint and varnish remover, I've not used that particular product. I don't use strippers often but for the most part they all work the same - you brush on the stripper, let it set/work and then scrape off the gunk. It may or may not take more than 1 application. Some strippers need to be neutralized when done. Chemically stripping coatings on wood is always followed by sanding.
