how can I remove carpet glue from hardwood flooring
Old 05-15-13, 01:46 PM
0
I scrape a bunch of it off by hand in my hallway, but that took a long time and there is still a lot left. I am going to be removing some carpet in a bedroom that was glued down as well and I'm looking for some suggestions to get the stuff to come up easy with out damaging the hardwood.
Old 05-16-13, 02:34 PM
sam floor's Avatar
Received 37 Upvotes on 31 Posts
The wood needs to be refinished. The glue will sand right off.
Old 05-24-13, 04:55 AM
C
Remove glue.
You can remove glue with the help of acetone,it is a glue solvent try it.
Old 05-25-13, 09:35 AM
Received 1,267 Upvotes on 1,207 Posts
Acetone is pretty harsh to use and requires good ventilation. My first thought was mineral spirits and elbow grease but I like Sam's idea.
Old 05-25-13, 11:03 AM
Received 839 Upvotes on 736 Posts
IMO sanding is less work and the end result will be a LOT nicer!
