How Can I Match One Oil Based Polyurethane Wood Floor Section with Another?
Old 05-21-13, 08:28 PM
U
I live in a small space and I am refinishing the living room wood floor. There was no way for me to get all of the furniture into another room, so I placed it in a confined space in the room.
I sanded and applied one coat of polyurethane and it is drying and looks good. I will wait at least three days and then move the furniture to the area of the room that will be finished. I will then sand the unfinished area and apply polyurethane.
My question is- how do I best "connect" the two sections so that they look seamless? I imagine that I am going to have to go a little bit over the edge of the "finished" part when I do the second part.
Thanks for your advice.
Old 05-22-13, 05:13 AM
Received 839 Upvotes on 736 Posts
Stopping and starting where the 2 boards meet should work ok. Stopping mid way on a board is guaranteed to show!
Old 05-22-13, 05:27 AM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
If you overlap, you will always see the lap marks in the sheen where your last coat ended, since the poly goes down in thin layers like a sheet of plastic. You would have been better off if you carefully taped along the edge of a single plank and finished up to it.
Old 05-22-13, 06:55 AM
U
Hi. I had thought about creating a boundary line with tape, but I did not follow through with it unforturnately.
If the mismatch is very visible, can i sand down that area and then light apply a coat to cover that area and create a blended look?
Old 05-22-13, 09:26 AM
I'd sand down the blended area as you sand the remainder of the floor. It would never have occurred to me to use tape [I'm good with a brush ] but keeping a straight line where 2 boards meet is imperative to hide the fact that the whole floor wasn't refinished at the same time.
