Help with removing laminate flooring
Old 05-28-13, 12:43 PM
Question Help with removing laminate flooring
I want to remove some old laminate flooring that is buckled and chiped from my kitchen. I see that the flooring goes under the cabinets. Any advice on what to use to cut the flloring at the cabinets? Please help!!
Old 05-28-13, 02:31 PM
Received 1 Upvote on 1 Post
If it really does go under the cabinets then that's one of the reasons it failed.
Sure it's not just under the 1/4 round?
Now your stuck with using a Toe Kick saw with the smaller blade so it only cuts 3/8" or and ossilating saw that would take far longer.
