Installing new laminate floor in basement, need help
Old 06-05-13, 05:56 AM
I'm installing new laminate flooring in my basement and have some questions.
1. I know laminate is inferior, but my dogs would ruin hardwood and carpet, so laminate wins by default. Please don't tell me to go with hardwood or carpet, it's not going to happen. I've already bought the laminate anyway.
2. Should I install the laminate directly on top of the cement floor (with vapour barrier and underlay of course) or should I put down plywood first? I've read how it can be a bad idea to put plywood down on a basement cement floor, but will it be okay if I put down a proper vapour barrier first?
3. If I should use plywood, should I go 1/2" or 1/4?
4. If I use plywood, should it be glued or nailed down? Wouldn't nails just puncture the vapour barrier?
5. What type of adhesive should I use to piece together the vapour barrier? Tape or some type of glue/cement?
Thanks for the help
Old 06-05-13, 06:08 PM
Received 1 Upvote on 1 Post
You have a lose, lose situation.
I'd never use laminite below grade, it's just going to delaminate, and plywoods going to rot or delaminate.
Paint, linolium, or tile would have been far better choises.
Old 06-06-13, 04:09 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Total agreement with Joe. You don't need my second opinion, since you already disclaimered it in (1) in your post. If you must, use a good quality underlayment and leave 3/4" of space at the edges. This is more than normal, but you will have more expansion than normal in a basement. Below grade is not a great place to install laminate, although some manufacturers say it is ok. Remember, they sell the stuff, they don't install it.
Old 06-06-13, 04:36 AM
Just a dog peeing on it, or the normal dog slobber around the water bowl will be enough to distroy the flooring.
Old 06-06-13, 08:21 AM
P
I had 8mm laminate installed on vapour barrier over bare concrete 1.5 yrs ago in a basement. Basement has flooded over the floor a small amount, leaving it wet for a week, stuff has been spilt on it, etc. The floor is still fine, no de-lamination, a lit bit of curl on some edges. I guess I got lucky ...
Old 06-06-13, 11:56 AM
chandler's Avatar
Just as with all gamblers, luck runs out. Yours will happen in all eventuality. How long ago did it flood?
Old 06-06-13, 01:16 PM
I already have laminate in a different part of the basement and so far it's held up great. I bought the house 2 years ago and it's fine. Not sure how long it's been down as the previous owners did it.
Even if it's not a great choice, it's going in. I have hardwood upstairs and the dogs have scratched the hell out of it. I had carpet in the basement but the dogs ruined it. So whether it's a good idea or not, laminate is going in.
So just use a good underlay and vapour barrier then and don't bother putting down plywood?
Old 06-06-13, 01:41 PM
czizzi's Avatar
Make sure that the underlayment is rated for use as both a vapor barrier as well as a sound deadening material. Many are not rated as a vapor barrier.
Old 06-06-13, 01:55 PM
Will do. I bought a 2 in 1 item that says it's both a padded underlay as well as a vapour barrier.
I'm just still not sure if I should lay down plywood first
Old 06-06-13, 02:37 PM
chandler's Avatar
It won't help any, and will eventually become water damaged. Go with the vapor barrier and laminate. Good luck.
Old 06-06-13, 08:44 PM
P
@Shane
If your going to put down plywood, then here's what I did at another house.
First put down Platon membrane.Asphalt-caulk overlapping pieces.Then tongue and groove. Then normal foam. Then laminate
I have this installed in a basement for I think 7 years now.That basement regularly (multiple times per year) has water come in, and it does whatever it does under the Platon. Floor still looks great!
Sorry if this msg is messed up. I wrote this on my phone. Very frustrating experience!
