pet odor and stains in sub floor of mobile home
Old 07-14-13, 12:31 PM
K
I believe if I read correctly a couple coats of oil based kilz or poly urethane will kill the smell I just so happen to have some deck sealant for a new deck I installed can I use that and if I do will it reck the floor from apllying kilz later if it doesn't work it smells so bad im not sure if its in the walls to of my hall way but im hesitant to start ripping up floor and walls in a mobile home for fear the place will fall down around me so I just want to take care of the problem without ripping things out
Read more: http://www.doityourself.com/forum/so...#ixzz2Z37McnlG
Old 07-14-13, 02:09 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Deck sealant is made for decks. What Marksr suggested in his posts with the oil based Kilz is the only way to go. Deck sealant will eventually go away as you will note having to do your deck every few years or so. Kilz will totally seal the smell and stains in all around. Do it right.....once.
