Odd Shaped Room
Old 07-14-13, 06:58 PM
D
Odd Shaped Room
Can anyone help me please ? I am trying to install hardwood flooring in an odd shaped room (picture attached). Should I run one long line from the master closet to the master bedroom through hallway 2 and the run flooring the long way through the entry hallway stopping with a transition piece OR do I treat the master closet and the entry hallway as seperate areas and transition both.
Thanks for any help.
Old 07-14-13, 07:08 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Welcome to the forum!
Is this nail down hardwood or is this a floating product?
Old 07-14-13, 09:43 PM
D
Probably floating. Do you have a preference ?
Old 07-15-13, 03:24 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I believe Tolyn was getting to the possibilities of using reversing splines with nail down, where you can't with floating floors.
Not knowing your preference in design, you may create an easy transitional floor by changing direction with the flooring. Naildown would be the best for this operation.
Old 07-15-13, 06:18 AM
The other thing I was getting at is a floating floor would definitely require transitions at the master bedroom door and at the two hallways. Where nail down would likely would not.
Old 07-15-13, 06:28 PM
D
Thanks. I really appreciate it. I dont have a preference for the design, just trying to make it look good,.
