Super Cold Laminate on Cement - New Hardwood and Subfloor ?
Old 08-16-13, 08:56 AM
H
Hi Guys,
I currently have laminate floors over cement since my condo townhouse unit is on ground level. During winters the floor are frigid cold and it is impossible to walk without slippers and socks. I have checked all other leak sources but I still find floors to be super cold. I am planning to redo the floors and install some insulation. What are my options? I was told that I will need to create some subfloor put insulation and then put my hardwood floors.
I would like to get suggestions on what my subfloor should be? How should I tackle this project.
thanks!
Old 08-16-13, 09:20 AM
Received 1,281 Upvotes on 1,219 Posts
Is the concrete exposed anywhere that you can do a moisture test?
Lots of options other than wood, don't know if you're completely committed to that choice as you could also tile or install carpet.
Old 08-16-13, 10:07 AM
Received 871 Upvotes on 762 Posts
Concrete will hold cold or heat. You'll need to insulate and install a subfloor over the concrete to reduce the cold - something like what they do on basement slabs to keep the flooring dry. I only have a passing knowledge on that stuff but some of the others should be able to help.
Old 08-16-13, 05:20 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
I would opt to remove what you have, install grid heating and engineered flooring. Really, I'd put down tile, but you want wood, I am sure. You'll need to check with the flooring manufacturer to see if their flooring is compatible with grid heating, but it will keep the floor warm, while keeping you from building your floor up with insulation, sleepers, subflooring, etc. Quite a cumbersome task.
