Laminate flooring gap at door threshold?
Old 09-01-13, 02:48 PM
I will be installing laminate flooring along an exterior door threshold.
What would be the correct way to cover the recommended gap between the threshold and the plank?
The threshold piece is plastic so I don't know if I can nail quarter round to it or not, which is what I plan to do with the rest of the room. The floor will be about 1/2" lower than the top of the threshold.
Thanks
Old 09-01-13, 03:30 PM
You can always glue the 1/4 rnd to the threshold. Lay a strip of thin cardboard over the laminate first to provide clearance and remove it after the glue sets.
Old 09-01-13, 03:32 PM
XSleeper's Avatar
You'd probably want to pin nail/glue the shoe or quarter round to the threshold, not the floor.
Old 09-01-13, 04:06 PM
czizzi's Avatar
Laminate can slide along its lengthwise axis. I would narrow the gap at the door where only the shoe is used and expand the gap across the room for the planks that are in line with the door so that overall there is sufficient expansion coverage. This way, you can ensure that the edge of the laminate will not "peek" out from under the shoe, but also provide room for expansion across the length of the room. Pin or 18 ga. brad or glue the shoe to the door threshold such that the floor can slide easily underneath.
