Restoring faded perimeter of hardwood floor
Old 09-03-13, 10:05 AM
N
Just pulled up area rugs covering a 50-year-old red oak floor. The floor is in beautiful condition with a deep red color and rich patina. The problem is the 12" wide strip around the perimeter that wasn't covered by the rug - it is dull, faded, and has some white water spots. Is there a way that I can restore/revitalize the perimeter area without having to sand the entire floor and lose the otherwise beautifully aged finish?
Old 09-03-13, 02:07 PM
Received 821 Upvotes on 720 Posts
Welcome to the forums!
Pics might be helpful - http://www.doityourself.com/forum/el...-pictures.html
While you might be able to make it look better than it does now, the odds are any partial finish job will be noticeable.
Old 09-04-13, 05:08 PM
N
Old 09-05-13, 04:00 AM
Not as bad as I had envisioned. Wax might restore some of the luster [but would need to be removed if you do any refinishing] I'm not sure it's possible to eliminate the difference short of sanding the entire floor and applying fresh poly.
Old 09-05-13, 11:28 AM
Received 1,262 Upvotes on 1,203 Posts
I think time will fade the difference but if you can't wait as long as it takes, I would sand the entire floor and add a fresh coat of polyurethane, as Mark suggested.
