finishes for new oak floors?
Old 10-03-13, 12:32 PM
W
What wouild be the best finish for new installed oak floors? Both the stain and the varnish or clear sealer?
Stairs are in main part of home; high, heavy traffic.
Any ideas, comments appreciated.
Old 10-03-13, 12:46 PM
Received 1,273 Upvotes on 1,213 Posts
Polyurethane - 3 coats with a light scuff sand in between coats (have to remove the sanding dust before applying the next coat). Personally, I don't think I'd stain the floor but it's up to you if you want to do that before the poly - I like the color of raw wood with the amber of oil based poly on it.
Old 10-03-13, 01:33 PM
Received 857 Upvotes on 749 Posts
I also prefer the way oil base poly deepens the colors naturally in the wood and ambers as it ages. As noted, which stain [or not] to use is a matter of personal choice. So is the sheen although a satin sheen won't show wear as bad as a glossier finish.
If you decide to use a water based poly, go to a flooring store and see what they have to offer, normally their water based finishes are tougher than what you'll find at a big box store. Water based polys don't change the look of the wood any [other than sheen] and don't yellow any with age.
Have the stair treads been installed yet? If not, I'd suggest staining and applying 2 coats of poly prior to installation. That way the stairs are only closed for the time it takes 1 coat to dry instead of 3-4.
