Self Leveling Basement Prep Before Installing Vinyl Laminate Plank
Old 10-21-13, 01:34 PM
Hello,
I have 11' x 13' room in my basement that I wanted to install vinyl laminate plank in. I prepared the floor by cleaning and priming the concrete and laying down self leveling concrete using Mapei products. I am waiting for it to properly cure and planning my next steps.
I have found lots of videos and discussions about installing the self leveling compound and about installing vinyl laminate plank, however I wanted to know what is required before installation.
Question:
Does the new Self Leveling Concrete need to be sealed?
If so what is recommended, poly or sealant or both?
Question:
Does an underlayment need to be installed on the sealed floor before vinyl laminate plank is installed?
If so what is recommended for a basement installation?
Question:
Can anyone recommend a vinyl laminate plank brand, that is durable for a basement application, meaning resistant to dampness of a basement, and easy to install?
Thank you in advance for your kind response.
Mike
Old 10-21-13, 02:15 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Mike: Welcome to the forums! Cutting to the chase.....
1. not really, as it is a leveling compound not a seal coating.
2. Whatever the manufacturer of the flooring recommends. This will keep your warranty in place.
3. I have used Allure with good success, but I am sure there are others out there. If you have any dampness, get it under control before you begin any floor installation or it will all fail.
